查看: 977|回复: 0
[原创] 电子束蒸发Ar离子辅助沉积Si光学薄膜的特性
发表于 2007-3-20 17:51:19 | 显示全部楼层 |阅读模式
4 k1 q  ]# n1 V% X+ n9 o' t【摘要】 对用常规电子束蒸发和Ar离子辅助沉积所得的非晶硅光学薄膜的光学常数、表面形貌、热稳定性和湿度稳定性等进行了研究。结果发现Ar离子辅助沉积所得非晶硅光学薄膜的折射率大大提高,表面粗糙度明显降低,湿度稳定性和热稳定性也得到较大改善,但是光学带隙变窄,光学吸收增加。 - [0 X8 h" R" n: ]8 h8 v3 J: B
【英文摘要】 The optical constants, surface structure,thermal and humidity stability of amorphous silicon optical films have been investigated by using regular electron beam evaporation and Ar assisted deposition.It is found that Ar ion bombardment can enhance the refractive index,decrease the roughness and improve the thermal and humidity stability,and but it leads to the narrowing of the bandgap and the increase of the optical absorption.
GMT, 2025-10-15 , Processed in 0.026059 second(s), 23 queries .
