查看: 1623|回复: 1
双源电子束蒸发提高光学薄膜致密性的工艺研究
发表于 2007-3-20 17:43:17 | 显示全部楼层 |阅读模式
双源电子束蒸发提高光学薄膜致密性的工艺研究/ ?/ u( K8 F6 m5 B0 v5 r1 m
【摘要】 采用双源电子束蒸发的方法,在K9玻璃基片上蒸镀Si和SiO2得到的混合膜层,折射率不仅可调,而且比Si膜要高。用原子力显微镜(AFM)分别对单纯镀的Si膜与双源电子束蒸发镀的Si/SiO2混合膜层的表面形貌进行了观测,结果表明,前者表面疏松,有明显的孔洞结构;后者膜层表面细密。采用双源蒸发的成膜理论,对该方法提高膜层致密性的原因进行了探讨。 4 }$ k2 V; _, d+ L% R* b8 p1 `
【英文摘要】 This paper introduces the formation of optical thin film by the double source electron beam evaporation,the Si/SiO_2 mixed thin film is evaporated on the K9 glass.The reflectivity index of the film is adjustable and the it is higher than that of the Si thin films.The Si thin film which is evaporated by the traditional ways and the Si/SiO_2 mixed thin film evaporated by the double source electron beam have been characterized by atomic force microscopy(AFM).It is found that the fabric of the first one with la...
多谢分享,楼主辛苦了哈
GMT, 2026-1-12 , Processed in 0.033489 second(s), 24 queries .
