查看: 1303|回复: 1
[原创] 厚度对ZnS薄膜结构和应力的影响
发表于 2007-3-20 17:41:13 | 显示全部楼层 |阅读模式
厚度对ZnS薄膜结构和应力的影响! X$ n: |0 ]6 @. t0 x; S! k6 M
* k7 \  x" Z+ }) A3 T
  g- N3 G9 V  I , k: j+ |3 b3 x  v! C$ m
* i9 s2 F" b0 \【英文篇名】 Effect of thickness on properties of ZnS thin films
; M  C  I! t3 l9 F5 `0 _1 v【摘要】 用射频磁控溅射法在单晶Si基片上制备了4种不同厚度的ZnS膜,采用XRD和光学干涉相移法对薄膜的微结构和应力进行研究。结构分析表明,不同厚度的ZnS膜均呈多晶状态,并有明显的(220)晶面择优取向,晶体结构为立方晶型(闪锌矿)结构;随着薄膜厚度的增加,平均晶粒尺寸随之增大;薄膜的晶格常数在不同厚度下均比标准值稍大。应力分析表明,随着膜厚的增加,ZnS膜的应力差减小,在厚度为768 nm时的选区范围内应力差最小,应力分布较均匀。
3 t# ~/ A: w: N# E【英文摘要】 Four kinds of ZnS films with different thickness which were deposited on the Si substrate by IF magnetron sputtering are studied by XRD and the optical phase-shift technique in terms of its microstructure and stress.The result of microstructure analysis shows that the ZnS films with different thickness consist of fcc-ZnS nanoparticles and apparently have the preferred orientation(220).The films are made up by cubic structure,and the average grain size of films increases from 7.47 nm to(12.59 nm) as the film...
发表于 2008-2-27 13:30:59 | 显示全部楼层
怎么下载不了呢?
GMT, 2025-10-17 , Processed in 0.031205 second(s), 24 queries .
