Designs of infrared non-polarizing beam splitters$. F; M! P9 L' j# k- O0 j
Zheng Ping Wang, Jin Hui Shi, Shun Ling Ruan! C% Y! D$ v% [, I: `& r9 G
Science School, Harbin Engineering University, 2 Yiman Street Nangang District, Harbin 150001, China6 F# x( d& b+ x3 }; E. j9 x, ?
Received 21 February 2005; received in revised form 16 June 2005; accepted 17 June 2005
. t, N8 j) n# cAvailable online 27 July 2005) B2 \0 I# G" c) m
Abstract
5 u3 a5 r2 F/ j6 L- tWhen used at oblique angles of incidence, the reflectance and transmittance of thin films exhibit strong polarization effects
3 y# C) s, f% g8 g; c4 H0 H Y(PEs), particularly for the films inside a glass cube, which result from the fact that the tangential components of the electric6 ?, r# g4 E! w3 K- C4 Q* {- P
and magnetic fields are continuous across each layer interface. However, for many applications, the PEs are undesirable and3 S1 r: _- A* a+ ]
should be reduced. Therefore, the concept of non-polarizing beam splitter (NPBS) is proposed. Up till now, however, most8 o3 v6 E: E+ ?4 ]! m- U( Y; c6 E
of the reports of NPBSs are suitable for visible light. Therefore, it is necessary to find out some methods to reduce the PEs: S" W" [ I4 z
for infrared applications. A design method of the infrared NPBS in a cube is proposed, the theoretical analysis is given,
% [( B% m, K$ A- o adesigns for different substrates are demonstrated and the simulations of their optical properties are presented in this4 |1 g2 ?8 G7 u- ?1 d3 e
paper.9 S" l/ U* y0 v0 a
r 2005 Elsevier Ltd. All rights reserved./ ]3 O& y# j1 e1 {% X
Keywords: Polarization; Non-polarizing beam splitter; Optical thin film; Reflection-induced retardance |
您需要 登录 才可以下载或查看,没有帐号?注册
x
