查看: 981|回复: 0
[原创] Ion sources for commercial ion implanter applications
发表于 2007-1-26 16:14:02 | 显示全部楼层 |阅读模式
Ion sources for commercial ion implanter applications( W& r) `( Z& F* d2 \9 q
' g1 E; ]  f0 N/ p! T2 X/ |: H4 ?
Walther, S.R.   Pedersen, B.O.   McKenna, C.M.   . i7 c6 q8 G7 W% b, z
Varian Ion Implant Syst., Gloucester, MA, USA;1 V* ?: F8 O0 Z, B+ b; w
& t! V0 M; {8 H4 c, x2 ^This paper appears in: Particle Accelerator Conference, 1991. 'Accelerator Science and Technology'., Conference Record of the 1991 IEEE 7 _# \! @: T3 O3 k
Publication Date: 6-9 May 1991
$ z/ c  l4 I0 p' Y  |9 DOn page(s): 2088 - 2092 vol.4
' Y  g6 h, l; A, a' PMeeting Date: 05/06/1991 - 05/09/1991 3 H' G! ~% c) f% b) e& _
8 ^" O" |3 d# X) P& T0 yINSPEC Accession Number:4209383 * t7 Z  O6 J9 A9 q0 `
Digital Object Identifier: 10.1109/PAC.1991.164876 4 `0 a: h4 B3 M5 p% G5 p$ Y  ], d9 r
Posted online: 2002-08-06 17:48:43.0
$ L& w" \* x* e/ F
$ n4 x! @2 Q6 R! B
! A4 B8 r8 Z2 _( d 2 t* k4 W' A8 h7 v# m0 D# k% M  D2 {
& p* N/ O  H% c6 T# X
Abstract/ s$ m; P9 ^( a
The authors review some of the history as well as recent developments in the implanter ion source field. It is noted that ion sources for implantation have changed considerably since implantation was first used commercially. Dramatic increases in beam output have been sustained with each new generation of ion implanters. In addition to the drive for improved beam currents, the need of the implant users for reliable long-life operation has driven much of the new development in implanter ion sources. In addition, the opportunity to achieve new capabilities, such as buried oxide layers, has sparked novel ion source designs to answer the demand. Particular attention is given here to microwave ion sources, the single ring cusp ion source, and multicusp ion sources
GMT, 2025-10-14 , Processed in 0.024610 second(s), 23 queries .
