FDLC薄膜的化学结构对光学性能的影响
4 X2 x$ ]& k) U0 O- u刘雄飞,张德恒,齐海兵
. [) y0 e+ e5 J6 L! x; ?% N' ?0 x中南大学物理科学与技术学院,长沙410083
% I3 x) r+ `% W收稿日期 修回日期 网络版发布日期 2007-1-15 接受日期
# J `( x- M1 `, R: I摘要 研究氟化类金刚石(FDLC)薄膜化学结构对光学性能的影响,用等离子体增强化学气相沉积
. |' }! D% i- ~6 F& I2 W+ Q& { K
* `8 C8 W$ a& n0 y7 r
- u0 S' r$ V7 C' Z7 ` N- B P! p) G& |. M
(PECVD)法在玻璃基底上沉积氟化类金刚石(FDLC)薄膜,用俄歇能谱、傅里叶红外光谱(FTIR)、紫外?可见光分光光度计 (UV-VIS)对薄膜进行分析。分析结果表明:沉积薄膜是典型的类金刚石结构,薄膜中氟主要以C-F2键存在;随着沉积温度的提高,C-F2含量先增后减;随着F含量的增加,FDLC薄膜的sp3含量减少,sp2含量增加;光学带隙与sp2键含量密切相关,sp2含量越大,薄膜的光学带隙越小。
7 x# p6 H. ^- K; C$ r: n8 d关键词 氟化类金刚石薄膜 等离子体增强化学气相沉积(PECVD) 光学带隙 沉积温度 8 W8 m' f4 d4 Z t2 ?
4 c& p; E7 d/ R% e6 M7 E5 Y: I2 i
分类号 TN304-055 ( r9 @; [0 ]- D# f: b2 m+ S: d
3 X' D1 B3 F* @; ]" WInfluence of chemistry structure of FDLC film on optical property
* d5 a9 s7 F- c6 M3 m9 Z: x+ q0 d1 m, fLIU Xiong-fei,ZHANG De-heng,QI Hai-bing
4 _9 X# F- ]1 e- |' d5 aSchool of Physics Science and Technology, Central South University, Changsha 410083,China
( k" ]- j# Q2 n! h7 T$ _9 z# D# ~* l3 l: V4 s, @! n
. B$ Z0 C- ]: s) ^Abstract In order to study the influence of chemistry structure of FDLC film on optical property, the fluorinated diamond-like carbon(FDLC) films were deposited on the glass substrate with the method of PECVD, and analyzed by AES, FTIR and UV-VIS. The result shows that the deposited films are typical diamond-like structure and the fluorine in the films exists in the form of C-F2 key; the content of C-F2, increases in the first period and then reduces as the temperature continuously rises in the deposition process; the sp3 content of FDLC films decreases and the sp2 content increases when the fluorine content increases; the optical band gap has a close relationship with the content of sp2 key, and the more the sp2 content is, the smaller the optical band gap will be.
( v" V' X# l" x* t5 Q- t, qKey words FDLC film PECVD optical band gap deposition temperature |
