方案一:
7 o; T2 f9 O) b% i" a1.激光晶体(Nd:YAG)+ m7 E1 G6 ?% e7 V* }+ ^* K7 A
- q: q a$ K. z2 l' h' q3 U
镀膜:(入射角度为0度), |, ?4 C( T+ o- y1 J
S1:HR@946mm(最大); HT@808mm, T>95%; HT@1064nm&1319nm, T>85%
) |4 Q0 b" k3 I5 KS2:AR@946nm(最大),HR@473nm,R>98%( l7 o1 ]8 Z8 i( ` @
1 y& C" S! E$ Z3 i7 H @9 _2. 输出镜镀膜:(入射角度为0度)) T; h; L6 ?1 `3 k' ~
S1:HR@946mm(最大); AR@473nm
+ s' R1 G# C; h/ _ j7 W9 vS2: AR@473nm+ z4 k6 q7 k& a5 d' g+ C0 K
: R1 d A0 x# e- N9 R
方案二:
; ?5 _. K" I7 a' b% r$ c1.激光晶体(Nd:YAG)
% {3 Y# ]: g) B; s# @$ w6 x" Z7 P$ E, U
镀膜:(入射角度为0度)% Q& ~8 l. X# p5 l' m2 K( F3 Z
S1:HR@946mm(最大); HT@808mm, T>95%; HT@1319nm, T>85%
6 B- M/ c4 F% z) J+ P6 DS2:AR@946nm(最大),HR@473nm,R>98%
, ]5 s5 l j9 p) @
* c5 e* I5 `( W, r2 m+ `2 L2. 输出镜镀膜:(入射角度为0度)
: d/ e6 G- T! u4 e# YS1:HR@946mm(最大); HT@1064nm,T>85%,AR@473nm
( n2 R1 m" l: k# c% ?% A; Q+ AS2: AR@473nm* E( _5 {# I6 E: }
方案三:
7 H/ ]8 x* D8 P0 a/ W: w- i9 C8 v1.激光晶体(Nd:YAG): j8 r, J# V4 N$ P, |! F
# A! H( A+ f9 F0 b4 S7 `镀膜:(入射角度为0度)
$ z0 D% k- N1 S( u7 j! {( |" HS1:HR@946mm(最大); HT@808mm, T>95%; HT@1064nm&1319nm, T>85%;HR@473nm) }8 X9 D9 R4 I, P! i
S2:AR@946nm(最大),AR@473nm,R>98%
& M( h8 P3 @ o5 C5 I' R& k' s8 `) ^8 M" y# E3 v J
2. 输出镜镀膜:(入射角度为0度)
% H' V; W/ D8 w( M5 E% pS1:HR@946mm(最大); AR@473nm
8 m# w2 V' E& ]8 |( W8 [% sS2: AR@473nm |
