' z# ] @$ ]5 i1 u <P style="LINE-HEIGHT: 18pt; TEXT-ALIGN: center; mso-line-height-rule: exactly" align=center><B><SPAN style="FONT-SIZE: 14pt; mso-bidi-font-size: 24.0pt"><FONT face=宋体>真空冷冻干燥技术讲解⑵<SPAN lang=EN-US><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></FONT></SPAN></B></P>: l5 z. N" k7 }
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center" align=center><B><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 24.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">上海东富龙科技有限公司</SPAN></B><B><SPAN style="FONT-SIZE: 14pt; mso-bidi-font-size: 24.0pt"> </SPAN></B><B><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 24.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">张耀平</SPAN></B></P>
! L. r" r8 v. Y4 S2 A<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 56.6pt; TEXT-INDENT: -36pt; LINE-HEIGHT: 22pt; TEXT-ALIGN: center; mso-line-height-rule: exactly; tab-stops: list 56.6pt; mso-list: l1 level1 lfo2" align=center><B><SPAN lang=EN-US style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">第三节<SPAN style="FONT: 7pt 'Times New Roman'"> </SPAN></SPAN></B><B><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">共溶点及其测量方法</SPAN><SPAN lang=EN-US><o:p></o:p></SPAN></B></P>
$ i1 L3 e. P# S7 n- X/ S) b<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">需要冻干的产品,一般是预先配制成水的溶液或悬浊液,因此它的冰点与水就不相同了,水在</SPAN><SPAN lang=EN-US>0</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃时结冰,而海水却要在低于</SPAN><SPAN lang=EN-US>0</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃的温度才能结冰,因为海水也是多种物质的水溶液。实验指出</SPAN><SPAN lang=EN-US>:</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">溶液的冰点将低于溶媒的冰点。</SPAN></P>
2 ]! |! E8 a! ]5 T/ B( q<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">另外,溶液的结冰过程与纯液体也不一样,纯液体如水在</SPAN><SPAN lang=EN-US>0</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃时结冰,水的温度并不下降,直到全部水结冰之后温度才下降,这说明纯液体有一个固定的结冰点。而溶液却不一样,它不是在某一固定温度完全凝结成固体,而是在某一温度时,晶体开始析出,随着温度的下降,晶体的数量不断增加,直到最后,溶液才全部凝结。这样,溶液并不是在某一固定温度时凝结。而是在某一温度范围内凝结。当冷却时开始析出晶体的温度称为溶液的冰点。而溶液全部凝结的温度叫做溶液的凝固点。凝固点就是融化的开始点(即熔点),对于溶液来说也就是溶质和溶媒共同熔化的点。所以又叫做共熔点或共晶点。可见溶液的冰点与共熔点是不相同的。共熔点才是溶液真正全部凝成固体的温度。</SPAN></P>
; p9 s8 ~; b; c7 M. w<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">显然共熔点的概念对于冷冻干燥是重要的。因为冻干产品可能有盐类、糖类、明胶、蛋白质、血球、组织、病毒、细菌等等的物质。因此它是一个复杂的液体,它的冻结过程肯定也是一个复杂的过程,与溶液相似,也有一个真正全部凝结成固体的温度,即共熔点。由于冷冻干燥是在真空状态下进行的。只有产品全部冻结后才能在真空下进行升华干燥,否则有部分液体存在时,在真空下不仅会迅速蒸发,造成液体的浓缩使冻干产品的体积缩小;而且溶解在水中的气体在真空下会迅速冒出来,造成象液体沸腾的样子,使冻干产品鼓泡、甚至冒出瓶外。这是我们所不希望的。为此冻干产品在升华开始时必须要制冷到共熔点以下的温度,使冻干产品真正全部冻结。</SPAN></P> V& I2 }6 @+ P$ n
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">在冻结过程中,从外表的观察来确定产品是否完全冻结成固体是不可能的;靠测量温度也无法确定产品内部的结构状态。而随着产品结构发生变化时电性能的变化是极为有用的,特别是在冻结时电阻率的测量能使我们知道冻结是在进行还是已经完成了,全部冻结后电阻率将非常大,因此溶液是离子导电。冻结时离子将固定不能运动,因此电阻率明显增大。而有少量液体存在时电阻率将显著下降。因此测量产品的电阻率将能确定产品的共熔点。</SPAN></P># |% c$ i, E0 F/ Q9 F3 z3 f
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">正规的共熔点测量法是将一对白金电极浸入液体产品之中,并在产品中插一支温度计,把它们冷却到-</SPAN><SPAN lang=EN-US>40</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃以下的低温,然后将冻结产品慢慢升温。用惠斯顿电桥来测量其电阻,当发生电阻突然降低时,这时的温度即为产品的共熔点。电桥要用交流电供电,因为直流电会发生电解作用,整个过程由仪表记录(图十六)。</SPAN></P>
% K# z/ j. ]$ s$ Q ?<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">也可用简单的方法来测量,如图十五所示。用二根适当粗细而又互相绝缘的铜丝插入盛放产品的容器中,作为电极。在铜电极附近插入一支温度计,插入深度与电极差不多,把它们一起放入冻干箱内的观察窗孔附近,并用适当方法把它们固定好,然后与其他产品一起预冻,这时我们用万用表不断地测量在降温过程中的电阻数值,根据电阻数值的变化来确定共熔点。<IMG src="http://www.chinesevacuum.com/upload/2005120294121.jpg"></SPAN></P>
# U8 w5 w8 f# B% \6 E2 s! [( H# p1 S<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><IMG src="http://www.chinesevacuum.com/upload/2005120294636.jpg"></SPAN></P>7 a! o @" s9 L
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 coordsize="21600,21600" o:spt="75" o:preferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><v:path o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"></v:path><o:lock v:ext="edit" aspectratio="t"></o:lock></v:shapetype><v:shape id=_x0000_s1026 style="MARGIN-TOP: 5.4pt; Z-INDEX: -2; LEFT: 0px; MARGIN-LEFT: 90pt; WIDTH: 3in; POSITION: absolute; HEIGHT: 138pt; TEXT-ALIGN: left; mso-wrap-edited: f" type="#_x0000_t75" alt="" wrapcoords="-75 0 -75 21483 21600 21483 21600 0 -75 0"><v:imagedata src="file:///C:/Temp/msoclip1/07/clip_image001.wmz" o:title=""></v:imagedata><v:textbox style="mso-next-textbox: #_x0000_s1026"></v:textbox><?xml:namespace prefix = w ns = "urn:schemas-microsoft-com:office:word" /><w:wrap type="tight"></w:wrap></v:shape></P>
# ^3 v/ |: v( I) G4 E<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN lang=EN-US> <o:p></o:p></SPAN></P>$ U2 h/ }. z4 q3 P; m/ C; F! R
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN lang=EN-US><o:p></o:p></SPAN></P>
' c/ _5 _& |$ p$ c1 D<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN lang=EN-US><o:p></o:p></SPAN></P>. T' p$ Q) b* M4 b9 N' _( \
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN lang=EN-US> <o:p></o:p></SPAN></P> j& y7 z% l6 H4 ?0 X7 W3 @" w
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">把电极引线通过一个开关与万用表相连,可以不分正负极。如果冻干箱没有电线引出接头,则可以用二根细导线从箱门缝处引出,在电线附近涂些真空密封蜡,这样不致于影响真空度。待温度计降至</SPAN><SPAN lang=EN-US>0</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃之后即开始测量并作记录。把万用表的转换开关放在测量电阻的最高档(×</SPAN><SPAN lang=EN-US>1K</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">或×</SPAN><SPAN lang=EN-US>10K</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)。由于万用表内使用的是直流电,为了防止电解作用,在每次测量完之后要把开关立即关掉,把每一次测量的温度和电阻数值一一记录下来。开始时电阻值很小,以后逐步增高。到某一温度时电阻突然增大,几乎是无穷大,这时的温度值便是共熔点数值。</SPAN></P>
6 x3 v9 W- l0 h; V<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">用这种方法测量的共熔点有一定的误差,因为铜电极处多少有些电解作用。万用表对于高阻值没有电桥灵敏;另外,冻结过程与熔化过程电阻的变化情况并不完全相同,但所测之值仍有实用参考价值。</SPAN></P>
9 F: q- n. q, Y3 x<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">共熔点的数值从</SPAN><SPAN lang=EN-US>0</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃到-</SPAN><SPAN lang=EN-US>50</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃不等,与产品的品种、保护剂的种类和浓度有关。一些物质的共熔点列表二十二供参考,因实际的冻干产品还有其它成份。所以与此不相同。</SPAN></P>
: z! i3 `4 {* b. U<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 21pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 2.0; mso-line-height-rule: exactly; mso-char-indent-size: 10.5pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"> 表二十二 一些物质的共熔点(℃)</SPAN></P>% R d; {8 Y* U8 E6 y
<TABLE style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN-LEFT: 4.7pt; BORDER-LEFT: medium none; WIDTH: 415.75pt; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-alt: solid windowtext .5pt" cellSpacing=0 cellPadding=0 width=554 border=1>; K$ V4 }# e+ T
<TBODY>2 `2 y B# ]& |
<TR>
2 m4 @1 o% I4 B T5 }1 J/ E, Q( z<TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 0.5pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 313.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent" vAlign=top width=418>
6 i6 j- Q9 q1 }% I0 x5 G<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 72pt; LINE-HEIGHT: 18pt; mso-char-indent-count: 8.0; mso-line-height-rule: exactly; mso-char-indent-size: 9.0pt"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">物质名称</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P></TD>
6 K% S) \: [; b+ J<TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 0.5pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 102.2pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=136>5 s0 x |- p# ]2 u; t6 C F b( S" T
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">共熔点温度℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P></TD></TR>
6 `& H2 L! T w, v<TR>: H8 R0 r2 K1 N N" @7 E8 O% W8 U
<TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 313.55pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=418>
3 A+ E3 w5 u9 k4 g! ~" ~<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">纯水</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
+ K+ i2 M" }2 ?% g% Y. L) Q<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">0.85</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%氯化钠溶液</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
5 B; L! p) u8 R7 Q% l<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">10</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%蔗糖溶液</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>2 G% b+ p8 S G6 W- R& B; m$ b# K
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">40</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%蔗糖溶液</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
3 U( W2 a- Q" V( U6 _% L$ f. T) U1 s<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">10</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%葡萄糖溶液</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>$ i E; S5 I: ]. q3 A4 C
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">2</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%明胶、</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">10</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%葡萄糖溶液</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>" p+ R% G: W5 E) A$ T
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">2</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%明胶、</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">10</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%蔗糖溶液</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>0 J) G" b3 L' Y
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">10</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%蔗糖溶液、</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">10</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%葡萄糖溶液、</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">0.85</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">%氯化钠溶液</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>* e5 s: f7 ~: q3 ^7 d2 t( G
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">脱脂牛奶</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P> r1 l( D2 Q3 G4 t6 f2 E+ l% v5 L0 U
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">马血清</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>; I4 ^2 ` b& L& ~7 t
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">人参</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>4 C6 S% X) q# z
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">菠菜</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>; W5 S+ y1 |4 U3 `4 _0 w6 D: g
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">30</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">,</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">溶解度</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">1.95mol/L</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的甲级芬尼定磷酸盐</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
+ M S' ~0 B0 t/ G/ S<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">30</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">,</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">溶解度</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">0.12mol/L</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的吩妥胺磷酸盐</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
}- O( x3 O% J: U* y7 \% z( U<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">30</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">,</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">溶解度</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">1mol/L</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的甘露醇</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
2 U( E. l8 @9 Y4 ^- H# j<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">30</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">,</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">溶解度</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">0.6mol/L</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的乳糖</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>* [1 h. k/ ?6 {
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">30</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">,</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">溶解度</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">4.97mol/L</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的氯化钾</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
S! Y+ a" M+ n% k; i& j L2 f: T! S<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">30</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">,</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">溶解度</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">5.93mol/L</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的溴化钾</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>% E C% Q* }9 k# Q5 t4 T" |
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">二甲亚矾水</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
' g( C. P: [0 W6 Q+ ?<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">甘油水</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">(</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">丙三醇</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">)<o:p></o:p></SPAN></P>
3 ~" I0 H u! S<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">草莓</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>, y3 Y6 V% h! v$ j; ~" Q& E
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">冬虫夏草</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
8 q$ s- M7 f: O/ K<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">山药</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P></TD>
) y( z3 j# u: d% L- H6 G. E9 B<TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #d4d0c8; WIDTH: 102.2pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=136>
0 y- Z4 ^6 |! \<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">0<o:p></o:p></SPAN></P>
* l/ B( J# x/ d, v! y: U: x+ d' s<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">22</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>, E! T$ l" R8 Y& a
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">26</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
& O+ I8 Q' e3 Q: S8 k<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">33</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>" ]( T# h" i" }9 s2 `6 l1 o+ G
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">27</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>. o4 Y) V4 Q* J; x1 u
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">32</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
9 L/ D, h! d9 g4 T: |, u9 x, L$ ]<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">19</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>1 d; a S4 E" }' S% G. C2 m4 J5 o0 s7 t
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">36</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>* d" o. n$ G+ B
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">26</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>/ V4 P5 Y I0 `1 z( \. O: Y
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">35</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>" T( x+ U/ c) v" J4 e! G: r9 x9 e
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">15</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>% l j L7 j. h2 e9 J( l
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">6</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>8 s$ k" Y2 r% j4 j: H9 I* l3 a0 K
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">4.29</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>; ~% E* q, `5 J1 p: O8 H
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">0.75</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
( b, j" |: l4 O4 W) U4 ?<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">2.24</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
3 n+ z% _$ Q- \; W. [" T* R! a<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">5.4</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>) j4 Y! Y! ?9 U) q& S u5 n* P
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">11.1</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
% D1 t7 `9 w. g' {0 Z* H" N! ~% }<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">12.9</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
- M8 t: A, l6 n% ^' l. x1 C<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">73</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>. O# w3 E! j3 y: c9 a- M
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">46.5</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
e9 _- }% ]! Y6 g( l<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">15</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>
3 h1 z2 D6 b9 i9 w3 @: A<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">15</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P>! x% \7 Q: b( L) M( c0 ]& u) G) v
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">-</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt">20</SPAN><SPAN style="FONT-SIZE: 9pt; FONT-FAMILY: 宋体; mso-bidi-font-size: 12.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">℃</SPAN><SPAN lang=EN-US style="FONT-SIZE: 9pt; mso-bidi-font-size: 12.0pt"><o:p></o:p></SPAN></P></TD></TR></TBODY></TABLE>
6 A7 t( j% h$ |# s/ h' @<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN lang=EN-US> <o:p></o:p></SPAN></P></td>
( x( n+ D- N1 ~. x( m# Z ( r8 Y8 e( N* [2 b( f8 O: v
- l( `* A/ t! S Y/ |
; L! g2 b: ~% P5 S, R </td>
4 u. j& u9 ?, ^" \
. u" y" H2 I, U5 ^$ m7 x: u% P </table>7 |/ j' ?% Z3 Y
<table cellSpacing="0" cellPadding="0" width="98%" align="center" border="0"> |
